Virgin stream box multi room.
miggy
Hi guys, If I got this streaming box from VM for another room would I get my sport and movie channels on it? Or is it just a glorified freeview box.
Do you mean a Second Box, if you alrady sub to the Sports and Movies then yes, all that you have on your 1st box will be on your 2nd box.
Do you think it is worth getting one then. I have two tivo/360 conversion boxes. I just want something for another room. We have the full TV package so I am not sure if you pay for this box or is it free?. Thanks Krusty.
I would expect you to have to pay for anything that streams into another room. This would be what a multiroom sub is. A google search says.
Multiroom Support: You can add up to five extra Stream boxes around the house on a rolling monthly subscription.
I've got a vm stream box, think there a decent box. Just a heads up, you need to add a second box through vm. I did try an aftermarket box from market place. Which was a no go,even though advised not to. Gave it a try but wouldn't work. Hope this helps.
